楼主 |
发表于 2008-6-18 18:34:44
Windows正在跳过你的启动文件。如果网络可用,最小网络支持将被加载 Windows is starting the command prompt only Windows正在启动命令字符模式 Windows will prompt you to confirm each startup command Windows将提示你确认每一个启动命令 The compression driver cannot be set up correctly 压缩驱动程序不能被正确加载 Get a version from your vendor that is compatible with this version of Windows 从你的供应商那里获得一个与Windows版本相兼容的版本 Process the system registry 运行系统注册表 Create a startup log file (BOOTLOG.TXT) 创建启动日志BOOTLOG.TXT文件 Process your startup device drivers (CONFIG.SYS) 运行CONFIG.SYS文件中的设备驱动 Process your startup command file (AUTOEXEC.BAT) 运行AUTOEXEC.BAT中的启动命令 Load the Windows graphical user inte**ce 装入WINDOWS图形用户界面(GDI) Warning: Windows has detected a registry/configuration error. Choose, Command prompt only, and run SCANREG 警告:Windows检测到一个注册表或配置错误选择DOS操作模式,运行SCANREG Warning: Windows has detected a compressed drive access error. Choose Safe mode command prompt only, to help you identify the problem 警告:Windows检测到一个访问压缩驱动器错误,选择安全模式下的MS-DOS,来帮助你识别这个问题 Warning: Windows did not finish loading on the previous attempt. Choose Safe mode, to start Windows with a minimal set of drivers 警告:Windows在刚才尝试后不能够完成加载,选择安全模式,用最小驱动启动你的电脑 Warning: Windows multi-boot may not function correctly Check for system files in your root directory with conflicting extensions 警告:Windows不能够正确完成多系统启动,在你的ROOT目录里检查不一致的系统文件 Warning: the system configuration manager failed to run. Some of your real-mode device drivers may not initialize properly 警告:系统管理器运行失败,一些实模式驱动可能没有正确初始化 The BUFFERS setting(s) in your CONFIG.SYS file are too large. Default buffer settings will be used instead 在你的CONFIG.SYS里BUFFER设置太大。默认的BUFFER缓冲器设置将被使用 A memory allocation error occurred during startup<BR< p> >Restart your computer and select Interactive Start to identify the problem 在启动过程中内存分配发生错误,请重新启动你的计算机然后选用交互式方式启动来确定故障原因 Warning: the high memory area (HMA) is not available Additional low memory (below 640K) will be used instead 警告:高端内存不可用,低端内存将被代替使用 There is not enough memory for Windows. Remove some drivers from your CONFIG.SYS file, and then try again 对Windows来说没有足够的内存,请从CONFIG.SYS文件中移去部分加载的程序,然后再试着启动你的读入计算机 Your previous MS-DOS files were not found. 旧的MS-DOS文件没有找到,这常见于使用双启动的系统,另一个系统是DOS6 Your previous MS-DOS version is not supported. MS-DOS startup failed 旧的MS-DOS版本不支持。MS-DOS启动失败 Now loading your previous version of MS-DOS, please wait 现在正在加载旧的MS-DOS版本,请等待 Invalid setting in the MSDOS.SYS file:An internal stack overflow has caused this session to be halted MSDOS.SYS文件中无效的设置选项。系统堆栈溢出,系统挂起 Change the STACKS setting in your CONFIG.SYS file, and then try again 请改变CONFIG.SYS文件中的STACK设置,然后再试 Stack overflow 堆栈溢出 Integer divide by 0 整数被0除 Not enough space for environment 没有足够的空间 Run-time error 运行错误 Floating-point support not loaded 浮点运算支持没有装入 Null pointer assignment 无效的断点分配六、COMMAND中的提示信息 提示信息 说明 Stack overflow 堆栈溢出 Integer divide by 0 分母是0 Not enough space for environment 磁盘没有足够的空间 Run-time error 时钟错误 No fixed disks present 没有硬盘存在 Insufficient memory 内存不足 Invalid drive specification 无效的驱动器名 Invalid characters in volume label 无效的盘符 Invalid Volume ID 无效的卷标ID号 No target drive specified 目标驱动器没有定义 missing operating system 系统文件丢失 Non system Disk or Disk Error 不是系统盘或磁盘错误 Replace Disk and Press Anykey To Reboot 替换磁盘,按任意键重新启动七、SYS传送系统文件时的提示信息 提示信息 说明 Cannot find System Files 不能找到系统文件 System transferred 系统传送完毕 Disk unsuitable for system disk 目标磁盘不适合做系统盘八、FORMAT中的提示信息 提示信息 说明 Unable to write BOOT. 不能写引导扇区 Invalid media type 无效的磁盘类型 Parameters not supported 参数不支持 Cannot format a network drive 不能格式化网络驱动器 Invalid media or Track 0 bad - disk unusable 无效的磁盘或0磁道损坏,磁盘不可用 Format terminated 格式化终止 Disk Boot failure 磁盘BOOT区错误 Invalid system disk 无效的系统磁盘 Disk I/O error,Replace the disk, and then press any key 磁盘I/O错误,请换盘后按任意键。通常在读写软盘时出现此类错误 Non-System disk or disk error,Replace and strike any key when ready 无系统的磁盘或磁盘错误,请替换后按任意键 Too many open files 打开的文件太多 Access denied Insufficient memory 没有足够的内存访问被拒绝 Invalid drive specification 无效的盘符说明 Parse Error XX 分析错误 XX Incorrect MS-DOS version 不正确的MS-DOS版本 X% percent completed 格式化正在进行,已经完成X% Format complete. 格式化完成 XX bytes in bad sectors XX字节的坏扇区 XX bytes total disk space 磁盘的全睰占湮猉X字节 XX bytes available on disk 磁盘的可使用空间为XX字 Volume label (11 characters, ENTER for none)? |
