SB(Universal Serial Bus,通用串行总线)
" A, T3 D5 ^$ A+ V+ \( IUSDM(Unified System Diagnostic Manager,统一系统监测管理器)* B6 @7 P4 o+ b
VID(Voltage Identification Definition,电压识别认证)
. S9 n D& P" v4 {4 U. S) ?+ DVRM (Voltage Regulator Module,电压调整模块)% |( K# b& @4 h* P5 |9 G2 u$ v
ZIF: Zero Insertion Force, 零插力2 B& ^! {' ` Y) w' x/ u- a/ g
主板技术
7 o; N* Z5 T0 X. XGigabyte- r7 }" L# Y @7 p" P$ L1 G: u; [
ACOPS: Automatic CPU OverHeat Prevention System(CPU过热****系统)+ k9 O/ E7 D( P
SIV: System Information Viewer(系统信息观察)
: M8 x( f- L& x磐英
% c" x' Q. q4 c! C% vESDJ(Easy Setting Dual Jumper,简化CPU双重跳线法)
# ?+ a9 b; t# O' h; e浩鑫8 E) m! _! n# k! _2 g& Q
UPT(USB、PANEL、LINK、TV-OUT四重接口)
. Z5 H& Q) x+ P: Z芯片组
+ Z# b, ?- F, {( OACPI(Advanced Configuration and Power Interface,先进设置和电源管理)
2 m2 I1 {" ]1 {; sAGP(Accelerated Graphics Port,图形加速接口)( J6 j5 B; D& D5 V; n
I/O(Input/Output,输入/输出)6 S7 l$ b y0 Y
MIOC: Memory and I/O Bridge Controller,内存和I/O桥控制器
4 H+ m' a# A1 BNBC: North Bridge Chip(北桥芯片)# `# Y0 Z% E! w: W& o' [/ g ^7 h
PIIX: PCI ISA/IDE Accelerator(加速器). O7 ^, n* Y# i+ _- ^6 f
PSE36: Page Size Extension 36-bit,36位页面尺寸扩展模式
4 [: J0 H0 `* E, g/ ~0 {8 U$ ?PXB: PCI Expander Bridge,PCI增强桥
" c, X7 s, C' L" i {9 PRCG: RAS/CAS Generator,RAS/CAS发生器
, M2 W$ H) q/ d, G9 F6 V. USBC: South Bridge Chip(南桥芯片)2 J- ?$ @5 N. X8 R# @) H% b; f
SMB: System Management Bus(全系统管理总线)
- A8 [0 z- H; v2 w* X2 f8 WSPD(Serial Presence Detect,内存内部序号检测装置)
* K3 B2 Z) _3 j; ZSSB: Super South Bridge,超级南桥芯片
4 F' L: {6 Y" p2 S8 STDP: Triton Data Path(数据路径)
- k( _# J+ H) U$ F. N' KTSC: Triton System Controller(系统控制器)
# n! j" z- V8 Q% E4 p( }% IQPA: Quad Port Acceleration(四接口加速)& b1 J; \! E& c
<!--EndFragment--> |
