楼主 |
发表于 2008-8-29 21:12:18
这是国外的几个超声波测距电路,供大家参考!
SRF04 - Ultrasonic Range Finder.
Voltage - 5v only required
Current - 30mA Typ. 50mA Max.
Frequency - 40KHz
Max Range - 3 m
Min Range - 3 cm
Sensitivity - Detect 3cm diameter broom handle at > 2 m
Input Trigger - 10uS Min. TTL level pulse
Echo Pulse - Positive TTL level signal, width proportional to range.
Small Size - 43mm x 20mm x 17mm height
Low Cost
?2.99
Purchase
Timing & Connection Diagrams
SRF08 - High Performance Ultrasonic Range Finder.
SRF08 Specification
Current - 15mA Typ. 3mA Standby.
Frequency - 40KHz
Range - 3cm -6m.
Max Analogue Gain - Variable 94 to 1025 in 32 steps.
Connection - Standard I2C Bus.
Light Sensor - Front Facing light sensor.
Timing - Fully timed echo, freeing host controller of task.
Echo - Multiple echo - keeps looking after first echo.
Units - Range reported in uS, mm or inches.
Small Size - 43mm x 20mm x 17mm height.
Full Technical Data and a little History
Example programs for
Atom, BS2 Stamp, BX-24 and OOPic
to get you up and running quickly.
ANN Mode,
for use with Neural Networks
Price
?5.50
Purchase |
