显卡测试软件MATS及其部分说明:该部分内容回复后可见
mats -h
MATS is short for Modified Algorithmic Test Sequence
Based on an algorithm described in 'March tests for word-oriented memories'
by A.J. van de Goor, Delft University, the Netherlands
MATS Options:
-e xx Forces endpoint of test to megabyte xx 强制测试兆字节(终端)xx点
-c xx Only test xx percent of the framebuffer. 仅按xx百分比测试帧缓冲区
-b xx Forces start of test to megabyte xx 从兆字节处开始强制测试
-o Suppress file output 禁止文件输出
-m xx Set the maximum number of errors to log 设置最大错误数记录(日志)
-n xx Run the algorithm on the card with index xx 以索引xx在卡上运行算法,'xxxx'在boards.dat文件中
'xxxx' in the boards.dat file.
-v Disable save & restore of VGA memory space 关闭存储和复位VGA内存空间
-ver Display version information 显示版本信息
-x Don't use the box algorithm 不使用寄存器算法
本人用MATS此软件只是做一参考并不能直接知道那个显存和其与GPU的线路的好坏。如显卡花看不出可以用PCI显卡带着跑。
